stephan.cat 28 Geschrieben 28. November 2011 Geschrieben 28. November 2011 neues aus dem Hause Liebherr für Hafen und Offshore Einsätze. Universal Crane TCC 14000-400 D LitronicIn June this year OOO Liebherr-Russland and OOO Lukoil–Kaliningradmorneft signed a contract for a new combined mobile harbour and offshore crane to be delivered by the end of 2012.The new crane is designed for two completely different types of application: on the one hand, the TCC 14000-400 D Litronic® can be used in harbours as a powerful crane for lifting heavy loads up to max. 400 t. On the other hand, it is possible to drive the crane onto a floating installation (barge) where it is fixed and used as an offshore crane under offshore conditions.The crane’s special feature lies primarily in its design as it was developed using existing technologies from the offshore crane and mobile harbour crane product groups. For the undercarriage of the TCC 14000-400 D Litronic® the drive technology of a Liebherr mobile harbour crane was combined with a newly designed steel fabrication: it consists of a central X-shaped structure to which four outriggers are mounted. For travelling operation the base structure is fitted with 48 wheel sets as known from the conventional Liebherr mobile harbour crane. During crane operation the crane is propped up on support units situated at the end of the outriggers. The dimensions of the support base are 22 m x 22 m. Using a large number of wheel sets and accordingly large supporting pads the crane achieves equally low ground pressure values as a standard mobile harbour crane, not only while travelling but also during crane operation. The TCC 14000-400 D Litronic® was developed under close consultation between Lukoil–Kaliningradmorneft and Liebherr–Werk Nenzing GmbH. The crane’s wide variety of application possibilities mainly result from the close cooperation of two R&D departments – the mobile harbour crane and offshore crane departments.In autumn 2011 the specialists of Liebherr-Werk Nenzing GmbH finished project documentation for the new crane. Production is now commencing.Max. outreach – 70 mMax. lifting height – 68 mDead weight – 1,100 tAvailable – autumn 2012QUELLE mit Bilder: OffshoreWind Zitieren
kranhuber 0 Geschrieben 30. November 2011 Geschrieben 30. November 2011 neues aus dem Hause Liebherr für Hafen und Offshore Einsätze. Universal Crane TCC 14000-400 D LitronicIn June this year OOO Liebherr-Russland and OOO Lukoil–Kaliningradmorneft signed a contract for a new combined mobile harbour and offshore crane to be delivered by the end of 2012.The new crane is designed for two completely different types of application: on the one hand, the TCC 14000-400 D Litronic® can be used in harbours as a powerful crane for lifting heavy loads up to max. 400 t. On the other hand, it is possible to drive the crane onto a floating installation (barge) where it is fixed and used as an offshore crane under offshore conditions.The crane’s special feature lies primarily in its design as it was developed using existing technologies from the offshore crane and mobile harbour crane product groups. For the undercarriage of the TCC 14000-400 D Litronic® the drive technology of a Liebherr mobile harbour crane was combined with a newly designed steel fabrication: it consists of a central X-shaped structure to which four outriggers are mounted. For travelling operation the base structure is fitted with 48 wheel sets as known from the conventional Liebherr mobile harbour crane. During crane operation the crane is propped up on support units situated at the end of the outriggers. The dimensions of the support base are 22 m x 22 m. Using a large number of wheel sets and accordingly large supporting pads the crane achieves equally low ground pressure values as a standard mobile harbour crane, not only while travelling but also during crane operation. The TCC 14000-400 D Litronic® was developed under close consultation between Lukoil–Kaliningradmorneft and Liebherr–Werk Nenzing GmbH. The crane’s wide variety of application possibilities mainly result from the close cooperation of two R&D departments – the mobile harbour crane and offshore crane departments.In autumn 2011 the specialists of Liebherr-Werk Nenzing GmbH finished project documentation for the new crane. Production is now commencing.Max. outreach – 70 mMax. lifting height – 68 mDead weight – 1,100 tAvailable – autumn 2012QUELLE mit Bilder: OffshoreWindDie Pressemitteilungen aus dem Hause Liebherr bringen immer wieder zum schmunzeln. Nachdem, was im aktuellen Fall beschrieben wird, müsste dieses Gerät schienenfahrbar sein .http://de.wikipedia.org/wiki/Radsatz Zitieren
speddy 2 Geschrieben 3. Juli 2013 Geschrieben 3. Juli 2013 (bearbeitet) Da ich weder bei Liebherr noch sonst wo aktuelle Infos zu diesem Kran gefunden habe , mal hier die Frage ob jemand von euch etwas aktuelles weiß?Wurde der Kran bereits ausgeliefert? Datenblatt? Aktuelle Bilder? bearbeitet 3. Juli 2013 von speddy Zitieren
stephan.cat 28 Geschrieben 9. August 2013 Autor Geschrieben 9. August 2013 Hallo speddy,danke für dein Interesse an dem Projekt Universal Crane TCC 14000-400 D Litronic.Ich habe mich mal bei Liebherr schlau gemacht und kann folgendes Update dazu geben:Der Kran wurde bereits ausgeliefert und montiert und arbeitet momentan auf einer Barge im Nördlichen Teil des Kaspischen Meers.GrußStephan Zitieren
Torsten K 57 Geschrieben 9. August 2013 Geschrieben 9. August 2013 danke für dein Interesse an dem Projekt Universal Crane TCC 14000-400 D Litronic.Man könnte glatt meinen du bist der offizielle Pressesprecher.... Zitieren
