S 46 0 Geschrieben 28. Januar 2010 Geschrieben 28. Januar 2010 (bearbeitet) My dear friend Liviu... ahem.Do you know how long I tried to get, unsuccessfully, hold of data or pictures of K 2500 and alike ?And now you post these without warnings !!You gave me a heart attack tonight !THANK YOU ! bearbeitet 30. Januar 2010 von Beat Zitieren
S 46 0 Geschrieben 28. Januar 2010 Geschrieben 28. Januar 2010 So the K 2500 is more the little version of K 10000... and topslewing ?I can`t find words...But the K 5000 still seems to be totally normal... ( with the A - Strut Topmast).Or are you also gonna prove else ?I challenge you to do so !! Zitieren
djlivus 0 Geschrieben 30. Januar 2010 Autor Geschrieben 30. Januar 2010 QUOTE(S 46 @ 28.01.10 - 22:44) ←So the K 2500 is more the little version of K 10000... and topslewing ?I can`t find words...But the K 5000 still seems to be totally normal... ( with the A - Strut Topmast).Or are you also gonna prove else ?I challenge you to do so !! @ s46: I'm glad you enjoied these pictures. You are right k-5000 has a usual structure of the tower , but it is from 2003-2005 or so. Instead the k-2500 in these pictures is an oldtimer from 1986. The present kroll k-2500 is also similar with k-5000. Zitieren
djlivus 0 Geschrieben 30. Januar 2010 Autor Geschrieben 30. Januar 2010 new k-2500 Kroll_K_2500_Portal.pdf Zitieren
djlivus 0 Geschrieben 31. Januar 2010 Autor Geschrieben 31. Januar 2010 Favelle Favco M2480D Lifting capacity: 330 tonnes @ 14.4 m radius with 36.9 m boomMaximum boom length: 92.7 mMaximum lift at maximum radius: 20.6 tonnes @ 91.3 mMaximum freestanding hook height: 170 mLine pull: 55 tonnes, high speed winchWinch speed: 95.5 m/minHeaviest component: Machinery deck front piece, including slew drive, pins and handrails 29.4 tonnesTail swing radius: 11.9 m Zitieren
