Europas größte Bau & Baumaschinen Community - Mitglieder: 37.272
Potain GMR 208/ 209/ 210/ 215/ 218/ 220/ 222/ 223/ 236
Hello, all !
Roadix, maybe you can tell if it is also a 210 on Holger's photos. One of them shows the mention 1000 kg / 20 m on the jib. I don't know if it is like this on the 210. I think it could be a 215 too,
Regards,
Jeff
Hello Jeff!
I think it is something between 210 and 215: as far I know it can't be a 215 because of some reasons:
- the hook block (2 rope-falls; shape like an "egg")
- lifting capacity of the 215 is 1000 kg @ 25m
- the tower diameter looks too "thin"
On the other Hand, you're right - a 210 won't lift 1000kg @ 20m (as far I remember, 210's capacity was @ 22m = ~650kg?)
So what could it be? 211? 212? I don't know for sure blush.gif bearbeitet von Boogie_blaster
Hello Jeff and Boogie_blaster,
I'm quite sure that it is a 210 on Holgers photos - the 210C I photograped has a load table which shows 1 ton at 22 m, 2 ton at 11,2 m. Also a lot of the constructive details seem to be identical. But of course, I cannot guarantee... wink.gif
Kind regards,
Klaus bearbeitet von roadix
Hier eine weitere Rarität - ein Potain 220 (Doppelteleskopmast, 27m Ausladung):
2007/10/post-1799-1192640614_thumb.jpg
