S 46 0 Geschrieben 24. November 2009 Geschrieben 24. November 2009 Well, I think it`s time now to get serious.The K 25000 waits behind me...I`ll do it today, djlivus, promised. Ah, and any comments, files, pictures are very welcome here...Post and share what you have! Zitieren
S 46 0 Geschrieben 24. November 2009 Geschrieben 24. November 2009 There is ( would be ) a lot to say about the K 25000.Foremost: It`s not designed to be the biggest, or highest crane ever.It is the consequent evolution derived from the experience made by producing the K 10000,and, obviously, created on demand of customers operating the K 10000.Like:- all machinery is now housed in a container above the slewing deck. ( sibirian climate ? )- much higher Masthead for much higher loading capabilities ( nearly doubled )- and this at further reaches and higher levels- top slewing ( discussed before, and probably after )- new towersystem ( TM 100 )- No A - Strut anymore- no element over 30 tons- total weight of crane indicated: 2.700.000kg ( ! )etc.Don`t get fooled by the overall sight. Keep in mind the dimensions which are described here.Or take the movable counterweights alone: 3 x 110 tons => That`s nearly the K 1400 operating weight itself.Which are then being propelled nearly 60 meters off axis ! That´s the lenght of a "normal" Main jib nowadays.And here it`s only the counterjib...I have to admit, that I`ve added fantasy to the drawings. But who can really tell, what the K 25000 will ( or would ) have looked like in reality?And that`s a good reason for drawings: They can show the virtual reality, when you`ve got no real picture of it.Ah, and I love pictures too.Enough said, up to the drawings. I have had to split them up, due to the 200K Limit, which I have to excuse,and will not put any text to it anymore, because I think, they are " selfexplanatory ".1.) Drawing of the Rail Base K 250002.) Drawing of the TM 100 System K 250003.) until 6.) Drawing of complete K 25000 crane with K 1400 ontop with different measurements.Of course I did more drawings ( comparisons, f. ex. with K 10000 ) but you have to send me a PN then,because they`re all above the 200K Limit.Cheers to all,it took me over 75 drawing hours to get until here, according to CAD`s statistics... Zitieren
S 46 0 Geschrieben 24. November 2009 Geschrieben 24. November 2009 K 25000 Railbase:Kroll_K_25000_Railbase.PDF Kroll_K_25000_Railbase.PDF Zitieren
S 46 0 Geschrieben 24. November 2009 Geschrieben 24. November 2009 K 25000 TM 100 SystemKroll_K_25000_TM100.PDF Kroll_K_25000_TM100.PDF Zitieren
S 46 0 Geschrieben 24. November 2009 Geschrieben 24. November 2009 1.)Kroll_K_25000_K_1400_measures__1of4_.PDF Kroll_K_25000_K_1400_measures__1of4_.PDF Zitieren
