Gast Geschrieben 6. Mai 2012 Geschrieben 6. Mai 2012 blue k10000 in SingaporeBlick aus der Kabine des blue k10000 in Singapore. Zitieren
S 46 0 Geschrieben 7. Mai 2012 Geschrieben 7. Mai 2012 Kroll? Or a chinesse model based on kroll? Anyway that krane is enormous...compared with humans size. A good find !Quite a while ago, I `ve stumbled on the same picture, and immediatly had to correct it`s size ratio.So I´ve concluded: Picture was taken in Geoje, DMSE, South Korea, and it is one of their Kroll K 1800`s,mounted on a 12m portal, using the TS 50 SS towersystem, with a reduced counterjib length.An imperativ, when being used for shipbuilding, seen also on Liebherr`s HC versions, used there.Obviously, picture was taken shortly after erection, performing load - tests. Btw.: The Kroll K 1800, currently used in Seattle, is said to cost a mere 2,2 million dollars, plus 250 thousand dollars for shipping to USA and erection work...just to remember about what we`re talking about Zitieren
Gast Geschrieben 7. Mai 2012 Geschrieben 7. Mai 2012 Blick aus der Kabine des blue k10000 in Singapore. Und ein Blick nach hinten aus der gleiche Kabine Zitieren
djlivus 0 Geschrieben 15. Mai 2012 Autor Geschrieben 15. Mai 2012 MD1000 Potain. The talest mobile tower crane ever made. By S46 Potain_MD1000_Sivas_Kangal.pdf Zitieren
djlivus 0 Geschrieben 15. Mai 2012 Autor Geschrieben 15. Mai 2012 POTAIN MD2200. 125 m HUH. A magnificent tower crane.By S46 Potain_MD2200_1988.pdf Zitieren
